Pulling injectors and HPOP question - Ford Powerstroke Diesel Forum
Old 04-13-2012, 05:05 PM
Quick question. Do I need to pull the radiator shroud, fan, and dump coolant to remove some of the top hoses?
Printed Swamps instructions on injectors.
Are there any good write ups on HPOP removal?
Thanks Guys
Bergy1
Old 04-13-2012, 07:29 PM
there is a good hpop write up in the tech section. hardest thing is removing and retightening the hpop gear bolt. you dont need to pull the shroud, fan, or any hoses
Old 04-13-2012, 07:35 PM
Full A-Team Member
17* HPOP install in an OBS by Matt P
Easy job, just take your time
Old 04-14-2012, 06:36 AM
Thanks guys! Starting the HPOP now. Got the injectors out.
