Camber? - Ford Powerstroke Diesel Forum
Old 04-09-2012, 05:58 PM
Camber?
Did a rough country leveling kit on my 1997 f-250 and was wondering if the factory camber slugs are adjustable. If not what is the best camber kit to go with?
Old 04-10-2012, 11:18 AM
the stockers are somewhat adjustable. once its on an alignment rack you can see how far it is out and get the proper shims to adjust it. chances are with just a leveling kit you will be able to adjust it with the stockers. just remember that every camber change adjusts caster as well. its best to put the upper balljoint behind the front one, helps the truck drive straight and helps steering return to center.
