Any way to get 4" DP in an OBS? - Ford Powerstroke Diesel Forum
Old 04-07-2012, 06:32 PM
Ok so like the title says is there anyone out ther with a 4" DP in thier truck, and how much modification to the body did you have to make?
Im having trouble pulling the 3" exhaust downpipe out right now.
From what I have read 3.5" is the maximum you can go. I'd like to try and fit a 4" custom setup in the truck and I figured while I have the transmission out it would be the perfect time to enlarge the area in preperation for a 4".
Old 04-07-2012, 07:06 PM
Why do you want a 4" down pipe? That would be soooo much work. A 3" dp is hard enough to get in. It would be easier with the tranny out, but still.
Old 04-07-2012, 07:13 PM
Unless it is a really high horsepower truck then there is no real need or advantage for the 4" down pipe. I have seen plenty of 400+ hp trucks with a 3" or 3.5" down pipe.
Old 04-07-2012, 09:02 PM
a body lift and some serious time with a porta-power will git-r-done. but like others have said its a lot of work for very little gain. post pics if you attempt
Old 04-08-2012, 11:44 AM
3in is plenty for a 7.3. no need for 4in.
Old 04-08-2012, 12:23 PM
Send a message via AIM to baderic03
I make over 400rwhp and have a 3in dp
Old 04-09-2012, 04:49 PM
the baconator
yep a body lift
Old 04-09-2012, 05:26 PM
When I do it I'm gonna go for a 3.5" DP, I just need to figure out where to get one. I know it's been done.
Old 04-09-2012, 07:04 PM
ok then I guess im gonna stick with my 3", I had read a long time ago that the best exhaust after the turbo is no exhaust. So I was figuring that a 4" or 5" would have been best but if theres not much point then I wont try and strain myself to get a bigger downpipe when theres not much to gain from it. Maybe i'll just open it up enough so I can pull the down pipe out easier if it's ever needed, if i can open it up at all.
