94.5 vs 96 - Ford Powerstroke Diesel Forum
Old 04-07-2012, 05:21 PM
94.5 vs 96
What is the diffrence between the 94.5-95 "turbo diesel" and the 96 "power stroke" just trying to better understand!
Old 04-07-2012, 05:30 PM
94.5-95 are powerstrokes. Early 94's are turbo diesels which are an indirect injected 7.3 diesel. The idi's don't have a computers so you can't chip them and they have less power
Sent from my Autoguide iPad app
Old 04-07-2012, 05:34 PM
I understand....to be more clear why did Ford label the 96 Power strokes and not the 94.5-95. I know the 94.5 are direct injection just trying to understand the "labeling"
Old 04-07-2012, 05:35 PM
That I'm not sure. Its still a powerstroke though
Old 04-07-2012, 05:44 PM
In 94 or 94.5 (not sure when they started), but there were 3 7.3s: 1) N/A IDI 7.3, 2) Tubro Charged IDI 7.3, and 3) the Powerstroke. I believe the "turbo diesel" was the turbo charged IDI.
Old 04-07-2012, 05:48 PM
Ford started labeling Power Stroke in 96. All DI's prior was labeled Turbo Diesel. Thanks for the thoughts so far
Old 04-07-2012, 05:51 PM
i believe the only difference between the 94.5-97 psd is they changed something on the block in 97 just cant remember what it was
Old 04-07-2012, 06:14 PM
I think there are some differences in the hpops, like a drain back valve, I remember reading that somewhere. There is a difference in the blocks in 97s, I saw that somewhere, can't rememeber now though.
Old 04-07-2012, 07:56 PM
There a bunch of small differences between the 94.5, 95, 96, and 97 (not counting the late 96 and 97 California versions which got the split-shot injectors) . They are all PSDs (all are 7.3L Direct Injected Turbo Diesels that use the Hydraulically Actuated Electronically Controlled Unit Injectors (HEUI)). The 94's , no matter if they were Turbo IDIs or the PSD, were labeled as turbodiesels (no Powerstroke badges). 95-97's all got the PSD badging. Go to the "7.3L DIT Anthology" section of "this document" for more information. Hope this helps. Cheers!
Old 04-07-2012, 10:15 PM
Both of our '95s have PowerStroke badges, and are referred to as such in the owner's manual and diesel supplement.
