1997 F250 CHEAP WAY TO DO LIFT KIT? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-07-2012, 10:16 AM Thread Starter
1997 F250 CHEAP WAY TO DO LIFT KIT? Can i use blocks front & back? & is there anything else I would have to exstend? Or is there a cheaper & easyer way. Dont really want to add leafs cause the truck is already heaver then I want suspension wise!
evanlarade is offline
post #2 of 7 Old 04-07-2012, 11:41 AM
01Crewcab7.3's Avatar
RSK and super duty v code springs is the cheapest route I believe.
Tim
2001 F-250 Lariat CCSB, 4x4, ZF6 249k, 6.5" Procomp lift, 37" Toyo M/T's, 20" Fuel Hostages. PIS 160/30's, PHP Hydra, 6637, 4" exhaust, Tank mods, ISSPRO's, 08+ mirrors/tailgate/tail lights, M12000 winch.
01Crewcab7.3 is offline
post #3 of 7 Old 04-07-2012, 12:37 PM
erics diesel's Avatar
You need a Dana 60 to do rsk the only way with the ttb is to buy a kit from someone. And never put lift blocks in front
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #4 of 7 Old 04-07-2012, 12:51 PM
Yeah I realized after I posted that he said 250 not 350, wasn't sure if it was possible on the 50 or not so I learned something too.
Tim
post #5 of 7 Old 04-07-2012, 11:06 PM
backwoodsboy's Avatar
Absolute cheapest way? Throw a few hockey pucks where the body mounts to the frame.
You'll get what you pay for when it comes to lifting a truck. Simply adding blocks to the front would throw your suspension so far out of whack you'll be buying new tires every 5k.
Best way to lift the current configuration is to get a kit with new leafs, shocks, front axle pivot bracket and a drop pitman arm, and throw some 4" blocks under the rear.
Better yet would be to D60 swap the front and add 4" blocks to the rear. Should have you just about level.
Keep in mind the higher you get the truck off the ground, and the bigger tires you run, the shorter your ball joints/ wheel bearings/ axle u-joints / tie rods are going to last.
Chrome don't get ya home
backwoodsboy is offline
post #6 of 7 Old 04-07-2012, 11:38 PM
897.3alltheway!'s Avatar
Quoted: 11 Post(s)
the rear u can do blocks..the front maybe new springs
897.3alltheway! is offline
post #7 of 7 Old 04-10-2012, 12:28 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
guy here in so-cal selling full brand new never installed rancho lift kit i think it is, 4 inch lift for $750
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
