Help!!! - Ford Powerstroke Diesel Forum
Old 04-06-2012, 07:45 AM
Help!!!
I am going to install boost egt and trans temp gauge today and i have gotten started but thats. i have the A pillar out but now i need some help. i am rookie when it comes to wiring stuff up so if someone could please help me i am installing them on a 97 f250 thanks for any of the input.
Old 04-06-2012, 09:15 AM
Which part do you need help with? They come with schematics.
Old 04-06-2012, 12:27 PM
what plug do you take out and replace for the trans temp gauge i only see one bolt head on the driverside of the tranny and it is right above the tranny pan? is this the one.
Old 04-06-2012, 05:16 PM
sounds right.
it is an 1/8" pipe plug
Old 04-06-2012, 05:56 PM
the baconator
when i installed my boost gauge i just cut and t-ed the map pressure line, it is coming off the passenger side of the intake y. i think it is 1/4 vacuum line. for the pyro (egt sensor) I drilled and taped the driver's side manifold on the bottom and installed the pyro there. you get a more accurate temp reading pre turbo
