Dana 60 swap ? - Ford Powerstroke Diesel Forum
Old 04-05-2012, 04:49 PM
Dana 60 swap ?
So I've been reading around, and I'm wanting to confirm my understanding of the swap. I've got a 95 ext cab 4x4 with the TTB front axle. I'm looking at swapping a Dana 60 from a 92(if I remember correctly) f350 dually. My question is, will al I need to do to the axle is pull my hubs and replace the ones on the D60 with them?
Old 04-05-2012, 08:33 PM
You either found something rare or a conversion. The 350 DRW 4x4 was only a option on the chassis cab. IIRC 91 was the changeover from kingpin to balljoints, your hubs should swap.
Old 04-06-2012, 08:05 AM
ok, I'm gonna try and run by the place its at and get a picture on my way into work. I'll post it and hopefully that will give a lil more info on what it is and help me figure out what I need to do. Cause I know a couple versions you could simply unbolt the spacers. Though I haven't seen any of them in person.
Old 04-06-2012, 12:07 PM
Hillbilly Deluxe
Feedback Score: 3 reviews
I should work fine... Why would you want to swap your hubs, just remove the dually spacers and swap it in...
Sent from my SPH-D710 using AutoGuide.com App
Old 04-06-2012, 07:15 PM
Here is a pic of the hub as best I could through the wheel.
It doesn't have teh simple spacers I was thinking, but I can't tell if its a setup that I'm gonna have to swap hubs all together.
Old 04-09-2012, 04:59 AM
Anybody have any input? I really need to figure out what I gotta do because this is my daily driver when weather isn't clear for my bike.
Old 04-09-2012, 05:21 AM
the baconator
if the hubs are different you can swap hubs with your current axle, but i thought the dually ran spacers
Old 04-09-2012, 07:53 AM
I know that some do, but I believe that some years ran extended hubs vs a simple adapter. I'm may just get it and hope mine will swap over fine. I'm hoping so, if not I'm gonna have to find and buy some SRW hubs.
Thanks again for the input so far, more help is always appreciated too.
Old 04-09-2012, 09:20 AM
the baconator
the hubs from the D50 ttb and D60 monobeam are the same hub
