6637 DIY Intake filter install/change - Ford Powerstroke Diesel Forum
Old 04-05-2012, 03:13 PM
Hillbilly Deluxe
Feedback Score: 3 reviews
So I decided to do a quick write up on the 6637 DIY Intake. I have been seeing a lot of posts regarding this mod and I needed to change my filter anyway.
First you want to remove your stock airbox from the intake tube.
Next you will need a 4" 45° elbow. A muffler shop should have one, if not you should be able to pick one up online for $20 or so. Another option is using a 4" pvc street 45° elbow and a small piece of 4" pvc. I used an exhaust elbow. You will need to cut it almost in half to make it short enough and get the angle right.
You will also want tp pick up a nice "t" style clamp. I like this style of clamp because you can get it really tight. I used the stock hose style clamp on the intake pipe.
Clamped up...
Installed in the truck...
I really needed to replace mine....
Sent from my SPH-D710 using AutoGuide.com App
Old 04-05-2012, 03:20 PM
dang thats a dirty filter.
Old 04-05-2012, 04:13 PM
That's an understatement.
Old 04-05-2012, 04:14 PM
it almost looks as if it was lit on fire. lol
Old 04-05-2012, 04:37 PM
wow that filter was dirty. lol
and i did the same with the exhaust elbow
Old 04-06-2012, 02:19 AM
Hillbilly Deluxe
Yeah it is, it had been a long time sense it had been changed... I still have it, i'll try to get a pic of the inside of the filter, it looks as clean as the new filter.
Old 04-06-2012, 02:30 AM
Hillbilly Deluxe
Filter Products - equipment parts - Donaldson, Baldwin, Des-Case, Wilson, Ingersoll Rand - alternators, air & electrical starters, bag, engine & hydraulic filters, bearings
Cheapest place to buy filters that i have found....
Old 04-06-2012, 05:46 PM
You sure it needed replaced ! Lol, don't think i could ever let mine get that bad.
Old 04-10-2012, 06:22 AM
i have bought the filter, still trying to get time to do the mod. i have searched around on it but i dont remember seeing what to do with the 2 sensors (if i remember correct) that are on the current box....can you help with that. 94.5 PS
Old 04-10-2012, 06:51 AM
how exactly did you get the 4 inch exhaust elbow to fit on that rubber tube? i made a bevel and after about an hour of wrestling with it, i got the 4 inch piece of pvc i needed in there.... i feel like should have something not so rednecked thered though
