How hard is the pedal assembly to remove?
Well, the cheap pot metal assembly that the pivot bolt for brake and clutch pedals finally cracked all around the bolt. Rendering my clutch next to useless. How much work is it to pull the assembly out? Looks like the clutch rod, master cylinder rod, 4 nuts, and one bolt near the top. And probably remove the steering stem? Any experience? Help!
it will come out with out pulling the column you mite have to take the one bolt in the shaft out and slide the rod down just watch the clutch pedal the spring can make it nock the poo out of ya
it's not too bad 1/2 hr or so. 6 bolts inside the cab 4 on the firewall (i think they are 15mm) and two under the dash(i think they are 10mm), two bolts in the engine bay on the firewall. undo brake pedal rod and clutch, undo the universal on the steering shaft. i find it easier if you undo the gas pedal as well
