ebpv gut - Ford Powerstroke Diesel Forum
Old 04-03-2012, 11:53 AM
ebpv gut
my ebpv actuator has began to leak. so i am going to gut it. couple questions because i havent done one of these in forever. on the valve itself where you remove the butterfly valve what size freezeplug do i need? my gut sais 3/4 or 19mm but i want to be sure so i can get the turbo in and out quickly. also when tapping the housing, will it be ok to use a 1/8 npt tap and a transmission pressure plug? i just wish i took some notes when i did these before. its been 4 or 5 years
thanks fellers, always good info here
Old 04-03-2012, 02:04 PM
You are correct on the freeze plug. I drilled and tapped and used a regular 1/8" plug didn't even think of a trans pressure plug.
Old 04-03-2012, 06:55 PM
thanks, i guess my memory is better than i thought. i appreciate the help
