Crank position sensor - Ford Powerstroke Diesel Forum
Old 04-01-2012, 08:06 PM
I'm new here and looking to find out if there is a Crank position sensor on a 1997 7.3l. I know there is a cam position sensor, but does it have or need both. My web search has not been definitive, so I'm hoping someone here knows.
Thanks for your help.
Old 04-02-2012, 08:52 AM
I believe there is only one CPS and it is often incorrectly referred to as a cam position sensor but it is reality a crank position sensor.
I may have that backwards but there is only one CPS.
Old 04-02-2012, 09:09 AM
CSP Resident Spooby
Theyre called either one, depending on who you ask. it's behind the fan, above the harmonic balancer, at about the 10 oclock position if I remember correctly.
Sent from my DROID X2 using AutoGuide.com App
Old 04-02-2012, 09:22 AM
the interrupter ring is on the camshaft, so it is a camshaft position sensor
Old 04-02-2012, 10:16 AM
camshaft / crankshaft. without it wont run no matter what you call it.
Old 04-02-2012, 11:26 PM
the pistons are connected to the crank, the cam moves the valves, two totally different things, but it is a sensor for the cam shaft
