Slow to start - Ford Powerstroke Diesel Forum
Old 03-31-2012, 10:38 AM
ODR ODR is offline
Slow to start
Truck seems to crank longer than usual to start lately. Thought it might be GPR and ordered the Stancor, but last nite I plugged it in even though it was warm out and when I started it this morning the wts light went off right away as expected. And it cranked for a long time to start again but as soon as it fired it started right up. Could it be starving for fuel at start up? Have efuel on way so it might answer my question. Any input would be appreciated this is my first powerstroke always ran cummins before.
Old 03-31-2012, 10:55 AM
Real Men Love Jesus! <><
check your batteries. what year do the stickers say on them? either that, or the starter is worn out.
Old 03-31-2012, 10:59 AM
Even tho the WTS light goes out, the glow plugs will be on up too two minutes at a time. The light has no indication of how long they are actually on. Your relay may be bad and since you ordered one already put it in. I think your fuel is just fine. My guess is that your batteries are on their way out. If they are over three years old, replace them with a good quality battery. You need to remember that these motors are damn reliable and that it is usually the simple and obvious things that go bad.
Old 03-31-2012, 11:46 AM
I had the same problem, put in a Stancor relay, still had the problem. I put in new batteries and that solved it, was like a brand new truck after that.
Old 03-31-2012, 02:02 PM
im gonna be due for batts this winter myself....
Old 03-31-2012, 03:28 PM
check the batteries and the cables for corosion
Old 03-31-2012, 05:18 PM
ODR ODR is offline
Batteries r fairly new I will clean the posts and will see what happens
Old 03-31-2012, 06:39 PM
If your batteries are good, then I would think your starter is shot. Solenoid is worn out
Sent from my Acer Android Tablet
Old 04-01-2012, 06:20 AM
Hey I jst went through the same thing, I put an amp meter on the cable, my starter was pulling 720 amps lol. You should see what yours is pulling.
Old 04-04-2012, 11:43 AM
ODR ODR is offline
Cleaned connections works like a charm feel silly for looking past obvious. Thank you for replies
