Fuel Bowl Delete Question. - Ford Powerstroke Diesel Forum
Old 03-29-2012, 10:13 AM
I'm servicing the IPR and to get to it I had to remove the fuel bowl. Now that is out, it's not going back in. I'm going to add an electric pump and a new filter housing deleting the fuel bowl. I know many others have done this. What do you do with the wires to the heater,fuel pressure sensor and water sensor? I know the IPR still needs to be plugged in.
Old 03-29-2012, 10:14 AM
This is in a 97 E450 Shuttle bus 7.3
Old 03-29-2012, 11:57 AM
when i did mine i just cut them, put a litle rtv in a wire nut and nutted each one of them.
Old 03-29-2012, 12:30 PM
Send a message via AIM to baderic03
I pulled my harness out pulled out all the plugs I didnt need and re wrapped the harness
Old 03-29-2012, 07:38 PM
Ok. thanks guys. So if they are not connected then they won't throw any codes or cause the problems. Just leave them unconnected and wrapped so they don't touch anything.
Old 03-29-2012, 07:41 PM
Correct they won't throw any codes
