What should icp be? - Ford Powerstroke Diesel Forum
Old 03-29-2012, 06:25 AM
What should icp be?
I have a 17* pump and stage 1s and my icp at idle is between 600 and 800 depending on which tune I'm using and wot on hot tune is 3000 psi. Is this good or should it be higher?
Sent from my PC36100 using AutoGuide.Com Free App
Old 03-29-2012, 06:28 AM
3000 is good but what is the DC%?
Old 03-29-2012, 06:49 AM
At idle around 17% I think ill drive it later and see what wot is
Old 03-29-2012, 07:00 AM
It doesn't really matter what it is at idle. the only thing that really tells you anything is at WOT
Old 03-29-2012, 09:48 AM
Send a message via AIM to baderic03
do a 50mph wot pull with some one watching the scanner and you should be under 50%
Old 03-31-2012, 10:03 AM
Yup 39% was the highest it went
