Serpentine Belt Fraying F-350 PSD 97 - Ford Powerstroke Diesel Forum
post #1 of 16 Old 03-28-2012, 07:00 PM Thread Starter
350ninty7's Avatar
Need a little advice / information about Serpentine Belt Tensioner and pulley alignment. IM fraying the belt( two new belts) to the point that it's throwing stringers off IM suspecting a bad idler and tension pulley. I changed out the Alternator and Power Steering Pump recently and now I have belt issues. The tensioner and idler are original so I suspect they need to be replaced.
Question.... pulley alignment what's the best way to guage for alignment with Water Pump and Crank if I didn't get the Power steering pulley correctly positioned? Is it easy to remove the Tensioner assembly or necessary ? Gotta be an easy fix, just need a little advice from someone that's had the problem.
Thanks
2012 F350 XLT 6.7 CC LWB SRW
11,500 GVW FX4 Off Road, Camper, & Prem XLT Options
2012 Montana Mountaineer 326 5th Wheel
SOLD and Missed
1997 F350 XLT 7.3 Liter Power Stroke
Reg Cab 4X4 Off Road Pkge
5 spd Manual with South Bend Clutch Upgrade
AFE Stage 2
Diamond Eye 3" Down Pipe 4" Exhaust Cat Delete
TW Tunes
WARN Winch
Original Owner 179,000 Miles
350ninty7 is offline
post #2 of 16 Old 03-28-2012, 07:11 PM
dieselwezel's Avatar
just throwing it out there,but since you replaced the alt. and power steering pump are they identical pulleys as the originals? I believe there is 6 and 8 rib setups.
1997 F-350 4x4
Flowmaster DP
Superchips max tuner...makes a good code reader
SD IC
DIY 6637
TW 6-pos
dieselwezel is offline
post #3 of 16 Old 03-28-2012, 07:35 PM
Patrick Feeley's Avatar
Quoted: 17 Post(s)
The very early PSDs (like my 94) had the 7-rib belts. The ones after that have the 8-rib. If the tensioner is bad, you should be able to see it tilted off to the side easily. More llikely the power stering pump pulley is out of line. My 97 kept shredding the inner rib (closest to the engine) of belts. After numerous belts, new tensioner, etc. all I needed to do was pull the PS pump pulley out about 2mm and problem solved. Use one of the pullers that are made for power steering pumps. Cheers!
Patrick Feeley is offline
post #4 of 16 Old 03-28-2012, 07:36 PM Thread Starter
350ninty7's Avatar
The PS Pump I used the original pulley, as for the Alternator I bought it at a Ford Dealer and they installed a new pulley for me because it went out while I was on traveling out of town. I didn't realize there are 7 & 8 ribbed pulleys. I'll check to see if it matches the ribs on the idler.
Appreciate the feedback and this a good item to check, very easily Ford sold me the wrong pulley.
Thanks
SOLD and Missed
AFE Stage 2
TW Tunes
WARN Winch
post #5 of 16 Old 03-28-2012, 07:39 PM
Quoted: 17 Post(s)
Since you posted about the same time (just after), read my post above. Cheers!
post #6 of 16 Old 03-28-2012, 07:47 PM Thread Starter
350ninty7's Avatar
Thanks.... That's where my belt is shredding, engine side. I have the pulley removal tool as that's what I used to install the pulley onto the new Pump. If it's shredding the outside edge (engine side ) wouldn't the pulley be out too far and need to to be pushed further onto the shaft? I should have measured the damn thing before I removed it off the OEM Pump. Anyway I'll cheeck the ribs on the alternator for a match adjust the PS Pulley.
Thanks
SOLD and Missed
AFE Stage 2
TW Tunes
WARN Winch
post #7 of 16 Old 03-29-2012, 09:43 AM
Thanks
I agree that its the pulley of the pump. Didnt the pulley has a "mark" where the serpentine belt has runned?
And yes I think it need to be pushed further onto the shaft IMHO.
CELAYORK is offline
post #8 of 16 Old 03-31-2012, 09:26 PM Thread Starter
350ninty7's Avatar
Need some info on Belt Size. I changed out the OEM Tensioner on my 97 which is a two pulley tensioner and Napa sold me the gates 081223. This is the same number that I removed because it was frayed and now the new belt 081223 won't begin to fit. I still had the OEM Mororcraft Belt in my garage that is saved a spare and it fit perfect problem is the part number is worn off. I think my issue with frayed belts within 5 - 6000 miles Napa 081223 is because they arre too small and the tensioner is too tight?
Napa is telling me that the 081223 is the belt required? That belt will not go on the new tensioner. Anyone running the OEM Dual Pulley Tensioner on their 97's. Ford dealer at the last resort. Anyone have a problem like this? Motorcraft Part #?
SOLD and Missed
AFE Stage 2
TW Tunes
WARN Winch
post #9 of 16 Old 03-31-2012, 09:37 PM
i have the same tensioner and 081223 is the belt i have.
1997 F-350 4x4
Flowmaster DP
SD IC
DIY 6637
TW 6-pos
post #10 of 16 Old 03-31-2012, 09:39 PM
http://www.powerstroke.org/forum/att...-tensioner.pdf
This was passed on by a member when i started a similar thread
1997 F-350 4x4
Flowmaster DP
SD IC
DIY 6637
TW 6-pos
