HELP! WITH TURBO SPUTTER - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-22-2012, 06:28 PM Thread Starter
Brfootball45's Avatar
Send a message via AIM to Brfootball45
i have a 95 powerstroke , edge chip with intake and exhaust ... tonight i disconnected the EBPV plug to stop it from killing my mpg. but now after starting it and go to take off the turbo makes a sputter noise, but goes away after driving a min or two after starting up. could this be the valve fluttering in the turbo? it never did this before unplugging
Brfootball45 is offline
post #2 of 6 Old 03-22-2012, 06:32 PM
baderic03's Avatar
Send a message via AIM to baderic03
Well first mpg shouldn't change w it unplugged or not and flutter check turbo play
97 f350single cab auto
4:10 axles spooled front axle
3in down pipe to stack
Intake 6637
140v idm mod
Efuel all built In house
II s475 .90 turbine spool....
Irate T4 304ss up pipes
T500 with gen3 pump
450/400s hush power
Comp built Trans 2100 stall converter
Gearhead tunes
531/1080 on 250/200s
baderic03 is offline
post #3 of 6 Old 03-22-2012, 06:41 PM Thread Starter
but it never did it before though? it did it after unplugging the ebpv
post #4 of 6 Old 03-22-2012, 07:14 PM
baderic03's Avatar
Well reach under and see if u can move the blade with it still attached. The valve is spring loaded open so it shouldn't matter unplugged or not. If you live where it's cold don't hammer on the truck till it warms up
Intake 6637
140v idm mod
T500 with gen3 pump
450/400s hush power
Gearhead tunes
post #5 of 6 Old 03-22-2012, 07:23 PM
jesilvas's Avatar
Quoted: 2 Post(s)
If it's closing when it shouldn't, it'll matter.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #6 of 6 Old 03-23-2012, 09:20 AM
95redrifle's Avatar
Quoted: 4 Post(s)
did you disconnect the sensor or the rod?
tony
1997 F250 4.10's
D60 swap/mag-hytec rear diff. cover
ts 6 pos./Autometers
melling LPOP/T-500 HPOP
D66 w/1.0 housing and WW2
160/80 rosewoods/bellowed up-pipes
08 king ranch seats/center console
south bend clutch
95redrifle is offline
