Reverse light switch on ZF trans
What the frequency of these things going bad? My lights don't work (have never worked since I bought the truck). I have diagnosed the problem yet but was wonder how frequent they go bad. I need them to back a boat trailer.
Subbed, mine have never worked either.
No reverse lights
Mine is broke as well. I have check the switched an my switch seems to work. So the problem is in the trans, guess they will stay broke. You could always wire a switch in the cab to jumper the trans switch. Then you could use it when you had to.
Greg |
Found time to get under the truck....The weatherpack plug-in harness connection is busted up...know where to buy plugs? Guess I try a salvage yard Friday.
