Hesitation on acceleration - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-19-2012, 08:04 AM Thread Starter
Nitro41's Avatar
Under light throttle and cruise everything is normal. at WOT the truck pulls hard and sounds great.
When I am cruising and start rolling into the throttle (to pass a car) the engine sounds like it kind of stumbles or misfires for about a second and then clears up and starts pulling nicely. I fugured It was just my HPOP not keeping up, but I just put a T500 in and does the same thing.
fresh fuel filter, cleaned fpr screen, rebuilt and healthy stg 1's, brand new T500, fpr shim, new fuel bowl hoses.
truck has 164,000 miles on it.definetly feels like a lack of power when jumping on the throttle or rolling into it. once you get it steady or wot...it pulls just fine..... any ideas???
I figured it might be my custom tunes since theyre for water meth, but my canned TS position 6 does the same thing. I have the FPR shim in, so Im assuming fuel pressure is good. and the factory lift pumps should support stg 1's
97 Single Cab F250 4x4 5 speed
Swapped D-60
Locked front and rear
160 sticks
Wildman Tunes
Hood Stack
OFE clutch
T500 HPOP
Linex rockers
35" MTR Kevlars
and a bunch more...
Nitro41 is offline
post #2 of 4 Old 03-20-2012, 01:41 AM Thread Starter
Nitro41's Avatar
Bump.
Recentl had cps changed at dealer too. Possibly a map sensor issue? I get some bad gauge flutter and maybe thats sending wierd pulses to the MAP
Swapped D-60
160 sticks
Wildman Tunes
Hood Stack
OFE clutch
T500 HPOP
Linex rockers
35" MTR Kevlars
and a bunch more...
Nitro41 is offline
post #3 of 4 Old 03-20-2012, 02:42 AM
Hillbilly Deluxe
STROKED_NY_023's Avatar
Quoted: 4 Post(s)
Feedback Score: 3 reviews
Unplug the map and see what happens?
Sent from my SPH-D710 using AutoGuide.com App
_____________________________________________
Seth
Stroked_NY_023
95' F-350 CCLB DRW POWERSTROKE
08 Axle/4x4 conversion, 5spd conversion, 6637, 5" SP exhaust, gearhead tunes
STROKED_NY_023 is offline
post #4 of 4 Old 03-20-2012, 03:27 AM Thread Starter
Nitro41's Avatar
I will try that when I leave work today. I was thinking the same thing.
oil has about 5000 miles on it just sent that in for analysis as well 5-40 rotella T6 synthetic. When I pulled the oil from the resivoir I noticed alot of tiny bubbles. I dont think its enough to be considered a foaming issue tho.
Swapped D-60
160 sticks
Wildman Tunes
Hood Stack
OFE clutch
T500 HPOP
Linex rockers
35" MTR Kevlars
and a bunch more...
Nitro41 is offline
