belt tensioner - Ford Powerstroke Diesel Forum
Old 03-15-2012, 02:50 PM
belt tensioner
It should move when you loosen it right? Mine doesnt move at all.
Old 03-15-2012, 03:06 PM
loosen? you put a socket on it with a long ratchet and pull towards the passanger side and it lifts up and you slide the belt out iirc
Old 03-15-2012, 03:28 PM
I loosened the center torx bolt and it didnt budge up or down
Old 03-15-2012, 03:34 PM
you dont use the torx bolt!! use a 15mm on the bolt it the center of the pully and pull it towards the passanger side
Old 03-15-2012, 03:40 PM
The torx is to take the tensioner off the truck.
Old 03-15-2012, 04:25 PM
that explains alot. Thx for clearing that up fellas. Feelin like a jackass right about now
Old 03-05-2013, 03:55 PM
Will a 1993 tensioner fit my 1996?
