Things to do While I have My Valve Cover Off? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-15-2012, 08:49 AM Thread Starter
So I think tomorrow I'm going to be pulling my covers off to check the wire harness. I am having an intermittent problem so I figure now's the time to check the wiring. When I have the covers off are there things I can clean or do to improve the performance of the engine? I plan on replacing the glow plugs because they are pretty well shot. Is there anything else?
Also are the stock gaskets rubber? The vehicle only has 135K
Thanks for any help!!
shinetimedetail is offline
post #2 of 7 Old 03-15-2012, 09:00 AM
zrain25's Avatar
That's all there is to do under there unless you want to do injectors but that's a bigger project.
Early 99 201,000 miles. Extra spring up front leveled, 4 in turbo back to 6 in tip, 6637, glow shift gauges, dp tuner, kicker speakers, alpine head unit and amp, kicker sub, extang tonneau, bedliner bumpers grill, flares, and rockers, 33in toyo mt, 18in xd monsters, 05 Harley lights, recon tails and line of fire, 20% tint
zrain25 is offline
post #3 of 7 Old 03-15-2012, 09:23 AM Thread Starter
How big of a project lol. I have 2-3 days to do this.
post #4 of 7 Old 03-15-2012, 12:18 PM
JD3020's Avatar
$1k+ bigger.
Just make sure that everything is in good shape, nothing bent or cracked. The gasket is rubber, and if the plugs look good reusable.
Jimmy
97 F-250 ECLB 7.3/E4OD/4wd, 216k miles: FFD 250/200%'s, stock turbo, built trans, e-fuel, Swamps IDM, shimmed 910's, Melling LPOP, welded cam gear/modified pick-up tube. Built and tuned by me
97 F-250 ECSB project truck:250/2's, Gen 3, S468, SD axles, studs/springs, ZF-6
JD3020 is offline
post #5 of 7 Old 03-15-2012, 02:33 PM Thread Starter
Originally Posted by JD3020 View Post
$1k+ bigger.
What would be bent or cracked? Is there a way to clean the injectors?
post #6 of 7 Old 03-15-2012, 02:43 PM
JD3020's Avatar
Valves, valve springs, push rods, and rocker arms.
And no, you can't clean em. Only thing to do is take them out and send em somewhere to get re-built or whatever.
Jimmy
JD3020 is offline
post #7 of 7 Old 03-15-2012, 02:49 PM Thread Starter
How bout o-rings?
