97 intermittent issue - Ford Powerstroke Diesel Forum
Old 03-14-2012, 09:04 AM
Not mine but my nieghbors and thought I would do some research for him. As stated it's a 97 with 180k on the clock. Manual trans, 4x4.
What's going on is the truck will run fine, then all of a sudden bog down and start clattering like there is air getting in the fuel, pull off the side of the road and shut the truck down. Wait for a couple of minutes then fire it up and it's all good again.
Last year he pulled a 5th wheel 170 miles one way with no issue. On his return trip the truck acted up 5 times, all within 20 miles of each other.
It is setting a check engine light but we don't know what it is yet.
Thoughts, suggestions?
Old 03-14-2012, 12:27 PM
I would get it scanned and see what code is being set. Otherwise maybe do a good inspection of the sensor wiring connections, and the fuel bowl wiring harness. Cheers!
Old 03-14-2012, 07:02 PM
Will AE work ln a 97?
Old 03-14-2012, 07:03 PM
If it's clattering, timing might be off. Timing, as in SOI.
Try a CPS.
Then UVCHs.
Old 03-14-2012, 07:28 PM
Diesel Freak
Cam position sensor ^
