dana 60 u bolt plate - Ford Powerstroke Diesel Forum
Old 03-10-2012, 06:06 AM
ok im going to look at a 95 dana 60 today its missing the drivers side spring plate and track bar mount how hard are these to find thanks for any help
Old 03-10-2012, 06:29 AM
Send a message via AIM to baderic03
i have one off a 78 dana60 i belive if you need it ill sell you it let me know
Old 03-10-2012, 06:38 AM
Hillbilly Deluxe
Feedback Score: 3 reviews
I needed a plate for my last truck, picked one up off an SD axle. You will need to cut the sway bar mount off, I used a 4" grinder with a cut off wheel.
As far as the sway bar mounting bracket, try a junk yard or Jeffs Bronco Graveyard...
You may be able to use both u-bolt plates and the sway bar off the SD, im not sure about fitment though...
Sent from my SPH-D710 using AutoGuide.com App
Old 03-10-2012, 06:39 AM
ok thanks im going to look in just a bit i will let you know
Old 03-10-2012, 06:45 AM
drivers side u bolt plate dont have a track bar mount on it it has a funky v casting for the center section
Old 03-10-2012, 06:54 AM
ya there 2 diffrent mounts sorry i wasnt real clear there
Old 03-10-2012, 06:57 AM
Hillbilly Deluxe
An SD plate hax the sway bar mount cast into it... It will work fine, I have done myself
Old 03-10-2012, 10:28 PM
Ok I got it now I need the spring plate and the track bar mount that goes on the truck
