2WD to 4WD conversion? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 09-18-2007, 11:16 PM Thread Starter
POWERSMOKIN's Avatar
Question 2WD to 4WD conversion?
So, i can find dirt cheap PSs but there all 2WD...
im going to most likely need the 4wd come winter here.
is there a 2wd to 4wd conversion kit? or is it just not worth it?
~Mike Lewis
1996 F-350 CC LB PSD
Beans Stage 1's - 6637 Intake - SD HPOP - 5" Exhaust
E4OD w/ Shift Kit - Sky MFG Reverse Shackle
265,000MI
POWERSMOKIN is offline
post #2 of 7 Old 09-18-2007, 11:18 PM
rankroddin250's Avatar
its not worth it. your better off finding a 4x4 .
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
The People of a free country should not be scared of their government, the government should be scared of their people.
rankroddin250 is offline
post #3 of 7 Old 09-19-2007, 06:32 AM
Let's Run'em
TwinTurboStroker's Avatar
Quoted: 5 Post(s)
Rank is right, its really not worth the trouble.....you think your saving money up front, but by the time you get the conversion done, you'll have spent almost twice what the mark up is for a 4x4 PSD....good luck finding one
-Julian
4th 6.fo
TwinTurboStroker is offline
post #4 of 7 Old 09-19-2007, 06:40 AM
duct tape & zip ties
bigcountrysg's Avatar
There is no conversion kit available. So you have to rely on part yards for everything you need, ebay for parts, craigslist, and other classifieds to obtain parts. You will need an axle, t-case, electronics, wiring harness, relays, bolts, nuts, and everything else. By the time you are done doing all the work, man hours, and hoping everything works right. Oh did I mention you will need a transmission for a 4wheel drive setup. Or at least the tailshaft of the transmission with adapter plate. By the time your all done you would have been able to go purchase a new truck or different truck that is 4wheeldrive. Now is there a cheap route you can go sure you can get customized driveshafts, 4 link suspension in the front, older divorced transfercase cut a hole in your floor for the shifter of the t-case, make custom cross members to support the t-case in place. You can do it that way but still after all the man hours and work is done. You still would have been better off to buy a truck that is already 4wheeldrive.
This topic has been discussed a few times on here. The end result is always the same there is no cheap way to convert and the cheapest way to do it is to buy a 4 wheel drive truck.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #5 of 7 Old 09-19-2007, 02:11 PM
BIG TRUCK, SMALL DRIVER
pipelayerjdh's Avatar
They are all right. It is way easier to just spend a little more for what you want.
I would not even attempt it on a SD, but the older trucks are easier to convert. You would still need many parts, or a whole parts truck, so you really don't save any money.
Derrick
'97 F-350 "FORDOR" 4X4 (Dually Conversion, Shackle Reversal, Technicooler , Auto Meter Gauges, 4" DIY Dual Exhaust w/ '08 tips,
, Wicked Wheel 2, 360 thrust bearing, Homemade E-fuel conversion, Wildman Chip,
) 230K and counting...
pipelayerjdh is offline
post #6 of 7 Old 09-19-2007, 05:47 PM Thread Starter
mkay. thats what i was thinking from the start, but yall just reaffirmed it.
~Mike Lewis
265,000MI
post #7 of 7 Old 09-19-2007, 10:22 PM
Electrical Ogre
alberta 7.3's Avatar
Quoted: 113 Post(s)
Did the 4X conversion on a '89 ranger (loved the truck and had too much $$$ in it to start with) Spent hours in the wrecking yard, and under the truck. spent a ton of money rebuilding axles, engine. front x-members are usally different between 2X and 4X, meaning custom fabbing is needed. End Result: spent a ton of money for a truck that wasn't really worth much
Bill
1996 F250 SC/SB 4X4 XLT
1997 F250 RC/SB 2WD project
2008 F350 CC/LB 4X4 DRW Lariat, 3" cow catcher mod
2008 Ranger SC FX4
Originally Posted by weareweird69 View Post
If your posting pictures bill, everyone dim their screens, that CAT YELLOW is bright
Originally Posted by Fordman247365 View Post
Is there anything you DONT take apart and **** with?
Originally Posted by JJFLASH View Post
I still say that those Dodge mirrors have as much business on a OBS Ford as yoga pants have on a fat chick...my .02
alberta 7.3 is offline
