Changing oil...
Total diesel noob here, so please be kind...
![]() Having just bought this truck, I want to change the oil right away since I don't know the last time it was done, or how long it's been, etc... Is there anything I need to do that is DIFFERENT than changing the oil in a gasser? I know there will be a LOT of it to drain (almost 4 gallons), but other than that, is it just a case of drain oil...remove filter...replace filter..replace oil? (Aside from the visual checks done while under there...) |
yep u pretty much got it... Not sure what you have for removing the filter but i bent all of my metal filter wrenches (the band style) I went out and got a strap style that hooks to a ratchet works way better
use a ford #1995 oil filter and i recomend 5-40 synthetic oil 14qts
Make sure to pre-fill the new filter before putting it on the truck. Typically filters will take close to 2qts once the element has had time to saturate. It will take a little time to pre-fill it properly, but dry starting a diesel is bad news.
Thanks for the Ford part# |
I've also used Baldwin filters. But you got the basic idea. |
Run 5-40 all year it don't matter summer or winter oil will still be 40w when hot.
OK...thanks for the "head's up" on the oil. I just bought a 20 gal pail of 15W-40 but once that's used up (I tend to change my oil a LOT on my vehicles) I'll use the Synthetic 5W-40.
