Ford 5spd manual reverse problems - Ford Powerstroke Diesel Forum
Old 02-26-2012, 04:28 PM
Just picked it up95 7.3, when I try to go into reverse the truck will pop it out and then grind. Is it the syncro's? I can get it in reverse when I roll the truck backwards... Every gear other than reverse is perfect.
Old 02-27-2012, 01:03 PM
the baconator
sounds like your reverse synchros are going out to me
Old 02-27-2012, 02:24 PM
ive had so many different answers, syncro's, bushings, and all sorts o0f **** i dont know what to say
Old 02-27-2012, 03:19 PM
Syncro and sliding collar. Teeth on collar are probably worn due to worn clutch pedal bushings.
Old 02-27-2012, 04:42 PM
how hard and how much $ to replace
Old 02-27-2012, 05:02 PM
Pull tranny and disassemble. Might as well do all syncros,bearings,seals while you have it apart. Not very difficult if you know what you're doing. Do need some tools to pull bearings/torch. I rebuilt my ZF with 1 new slider, all new bearings (including needle bearings and shift rail bearings), syncros and snap ring set. Had to take case halfs to Ford to pull bearing races as I had nothing I could heat the hole case with, charge $90 Total Cost $530, including the Ford bill
Old 02-27-2012, 05:06 PM
****, well thanks for your help.
Old 02-27-2012, 05:13 PM
It's really not that bad. If you can't do it yourself, get a buddy and at least pull the trans and have it ready to be rebuilt. Ask around, see if someone rebuilds them on the side. I've rebuilt them for $200. Where are you located?
Old 02-27-2012, 09:26 PM
Where are you located? I've been looking for a ZF-5 to pull apart in one of my engineering classes. If you pull the tranny and deliver it to me with a kit i'll rebuild it while I'm in there. Might cost you a 30 rack of the cheap stuff.
Old 02-28-2012, 04:08 AM
I'm in ct what about you? I could probably ship.
