Tranny cooler bypass? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 02-26-2012, 02:11 PM Thread Starter
My 96 is leaking tranny juice at the connection below the radiator. Is the cooling from the radiator "required" or can it by bypass and just use the top mount oem tranny cooler?
thanks.....
PioneerODR is offline
post #2 of 2 Old 02-26-2012, 02:47 PM
GAS
GAS's Avatar
yes it can be bypassed, if you are in a warm climate you may want to consider adding cooling capacity or replace your stocker with a V10 cooler
Micha, Pleasant Grove, Utah
99 F350 Crew cab long bed, Tymar intake(The real deal)
Zoodad, 4 inch exhaust, Dipricol gauges, WW,
gutted turbo pedestal and ebpv deleted big exhaust outlet, ccv delete
GAS is offline
