Can't pull codes on 97 F350
Three meters, from $50 to $250 can't pull a code from my truck even though the check engine light is on. I'm wondering if being a 97 it isn't fully OBDII compliant. One of the meters says there are 124 codes to pull but doesn't pull a single one.
Does anyone else have a 97 that they can pull codes from? What meter make and model do you use? Does anyone know of a certain type of meter that will pull from this early OBDII truck? Thanks in advance, BigRedWeather |
No it's not OBDII. Heck, not OBD. It's a CAN system.
You need a fancy scanner like Auto Enginuity with ford enhanced bundle.
Or you can buy a Superchips 1705 MAX tuner. Never had a problem pulling codes on mine with that. Happen to know a guy who's selling one over in the classifieds right now....and the added performance isn't half bad either
![]() But seriously, A.E. with the ford enhanced bundle is the way to go as far as scanning. |
