Bronco fuel tank swap
Looking to add some extra capacity to the rear with the bronco tank swap, but also want it to be a plastic tank in case I do the WVO conversion later on. Does anyone know if the stock tanks from the 90-96 broncos were plastic or steel? I'd like to know before I start crawling around underneath rigs at the junk yard.
STEEL. All Broncos from 1980- 1996 used the exact same gas tank.
Performance Injectors for 7.3L Ford Power Strokes
definitely steel, maybe aftermarket you can get plastic?
Titan Fuel Tanks just came out with a plastic 40 gallon replacement E250 and cab/chassis fuel tank.
Stock would be steel.
I've seen quite a few plastic bronco replacement tanks on my local CL lately though for dirt cheap. |
broncograveyard sells plastic tanks
alright next question, will the stock fuel sender for a bronco tank work with my gauges?
Ya it will work but it wont show the true fuel level bc there isnt enough travel in the float arm. Its all how u ajust the float. The way i set my tank up is i put the pick up tube about 3/4" from the bottom. And my float bottoms out at 3-4" from the bottom. So when i fill up i go about 2weeks, the first week the guage reads normal like to my front factory tank and then i run 1 week with the guage on E (little scary at first) and refill with 28gal of fuel. A rough est. Is im left with about 4 gall of fuel so i dont run out.
Sent from my Autoguide iPhone app while my boss isnt looking... Last edited by TANPOWERSMOKER; 04-26-2012 at 02:40 PM. |
If u run steel the diesel will wash off the galvannized finnish keep extra filters in the truck. It took about four tanks to clear up the diesel.
Sent from my Autoguide iPhone app while my boss isnt looking... |
