Injectors and aftermarket fuel sys
Ok so I have been looking and looking, I would like to find the most reasonable and good injectors stage one or two. And I was wondering about a different pump, I would like to be able to push more fuel without hurting anything. Or is there anything you can do to turn the stock pump up a little I know its not like the 12v that you can. Thanks
Sent from my C771 using AutoGuide.com App |
ok rosewood diesel will be the most reasonable on price on stage1-2 and as far as fuel goes you will be more worried about hpop not keeping up goto a factory superduty hpop or aftermarket
good tuning will help with proper fuel to the injectors just dont run a ts generic chip with after market injectors nothing will live |
T500 hpop and reman stage I or II injectors will be a great improvement. If you go with stage II injectors you will need to upgrade your turbo and will want to IC it. It all depends on your budget and target horsepower range.
My brain isn't working to do on a 97 250 aren't the hpop's 15* ? I found one is the only reason I asked. Ic y'all are running 17*
Yes stock obs is 15deg super duty is 17deg
Designs are almost identicle, so they're interchangeable. If you're getting a new HPOP anyways, no point wasting your money on a reman 15* when a T500 is only a hundred or so more. |
On the fuel side... Give Jake @Irate Diesel a call. He has some nice Stainless steel RR kits from tank to engine. Mine will be here Tuesday.
97 F250 5sp 4x4 work in progress |
Untitled 1 Irate Diesel performance ?Power Stroke Performance |
Firts on a OBS not all can swap to a SD 17* HPOP..the '95 will have leak down issues.
Stage 1's will work great with the stock fuel and turbo, if your 15* pump is in good shape it will keep up with demand. You will need a IC, Guages, intake and exhaust. If you have a auto and in good shape some mods should be added..VB and tq converter with a cooler. Stick.. a new clutch will be needed. Stage 2's..you will need a turbo, modded HPOP, studs, fuel system, if auto a BTS or JW trans..lots of $$$ We have everything for the OBS..PM me if I can help. |
