Truck pulls to right, w and w/o foot on brakes
Ok guys...need some insight on this...
The Problem: Truck is pulling to the right...to the point where I cant take my hand off the steering wheel to change the radio otherwise I go in to the other lane. This occurs at all times and seems to be worse when on the brakes. I do understand it is TTB but this just doesnt seem right! What I have done: New Wheels and tires. --When I noticed the initial issue..never did this before on the old wheels and tires. Realignment- with "camber adjustment kit" --done by Big O Im mad as I felt like I was just put through the ringer for an "adjustment" kit that doesnt help! Could it be a pad sticking? Just weird things occurred all at the same time coincidentally... |
i would check your front brakes and see if they are draging. since you just had an alignment done to me that could be the culprit or they didnt know what they are doing and just took your money
I think you may be right. Thinking the caliper may be going bad...going to try replacing that over the weekend and go from there. Should be pretty easy to do just tedious.
The plus side is Big O warranty's their alignment for 6 months so Ill take it back there again and have them realign free of charge after the caliper swap |
Have your alignment checked. Mine was doing the exact same thing. I just got it back from the shop a hour ago and its perfect.
Mine was doing the same thing. It turned out to be the axle was croocked. The locating pins were worn ans well as the u-bolts. Just something to check
dana 60 swap
i know that was no real help to you |
mine did that. the calipers were sticking and not releasing on the pasenger side. 67 dollars from lordco per side and bleed the brakes. away you go.
Update: Took my truck to the Ford Dealership because it was driving me crazy and they showed me what the problem is...my drag links (pitman arms) etc. are shot! the grease boots dont hold anything and they practically twist a (1/2) turn...grease was all over the place...
so, he was saying a lot of times these cheap shops, when pressed for time follow the motto "set the toe and let it go" meaning they set the toe to make her drive straight and then first big bump you hit they wobble back out of alignment. Most shops are supposed to check for any loose parts and then not proceed with the alignment if thats the case. So, the cost to fix everything from the steering box to the pitman arms will be close to 900 with labor and re-alignment.....so much for gauges D'OH! |
if it was me id take the reciept from the dealer to the place that originaly did it and demand a refund since they seem to be lazy and incompetent
lolThey honestly look like the original pitman arms, so Im pretty surprised they've gone this far! |
