carwash and rain with stacks - Ford Powerstroke Diesel Forum
post #1 of 13 Old 02-20-2012, 02:50 PM Thread Starter
clashem360's Avatar
Question carwash and rain with stacks
so i installed my stack and all looks beautiful but im scared to wash it now.
if i wash it and water goes into my stack wont it go into my engine and kill it? and i know if its running in the rain its fine but what if i park and leave it for a while? ive seen some guys put buckets on theirs around town and well it usually doesnt work. but yeah what can i do? or should i even worry?
clashem360 is offline
post #2 of 13 Old 02-20-2012, 03:27 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
i wouldnt worry bout it.... the reason buckets are used ar for tractors where the pipe goes straight to the enine, think about how the bends of the pipes are under the truck
it has to go down the pipe and fill up enought water to fill the entire pipe under the truck and keep filling untill it water level comes up to the turbo..... thats a LOT of water
but when water gets in there, you will spray water and sut over your truck when started. buckets will stop that
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #3 of 13 Old 02-20-2012, 11:00 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
they make covers as well for just that reason too
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 13 Old 02-20-2012, 11:26 PM
glovemeister's Avatar
A coffee can is not a bad idea, neither is drilling a small hole at the lowest portion of your bend for drainage.
glovemeister is offline
post #5 of 13 Old 02-20-2012, 11:44 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
but soot would come out it, make a petc0ck at the lowest portion, drain when necessary
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 13 Old 02-20-2012, 11:56 PM
444 ci's Avatar
i have got a drain hole in mine been that way for years. i never cover them and i havent had a problem.
444 ci is offline
post #7 of 13 Old 02-21-2012, 12:19 AM
A negligible amount of anything except for water would come down. I could figure out approximate collection in this pipe based upon diameter, and rain amount but do not feel like doing math.
post #8 of 13 Old 02-21-2012, 12:57 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
yeah unless its a monsoon i doubt much water would ever get in there anyway
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 13 Old 02-21-2012, 07:10 AM
Full A-Team Member
Fordman247365's Avatar
Thats what I did
Same here, have never had a problem and there is very little soot anywhere on any of my stainless
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
"100% worked for, 100% paid for"
Fordman247365 is offline
post #10 of 13 Old 02-21-2012, 09:35 AM
TANPOWERSMOKER's Avatar
If u drive it everyday then dont worry. If its a weekend truck, then u can do buckets or drill a hole at the lowest point.
-Brenden-
Theres Nothing Like A Good Cigar
95' F-250 7.3 EXTRACAB 4x4 LONGBED ZF5 238k
M.B.R.P down pipe,4" pipe to 5" turnouts, 6637 INTAKE, FPR SHIM, FP gauge, P.H.P. CHIP, Dana 60 swap, ccv mod, Issapro A-Piller Gauges, Aero force obd2 gauge, Rear 32gal bronco tank, 35" coopers(with no lift
), steel flatbed, home made 7ft track bars,Zf5 swap and valair cluch!!!
(I love Slaming beers...Oh, i mean gears)
SOON TO COME: Rosewood stage 1.5
TANPOWERSMOKER is offline
