400hp OBS? - Ford Powerstroke Diesel Forum
Old 02-17-2012, 06:41 PM
400hp OBS?
So I just got me a 1996 F-350 7.3L and it's bone stock. Is it possible to get 400hp/800tq out of these engines without dropping a load of money into it? I already have gauges, and I'm going to install a 4" exhaust, open up the intake, ts 6 pos chip, built tranny and t/c. I see most people change out the hpop and injectors. Is that about all I need to make this kind of hp?
Will an hpop off a SD bolt on and service my needs?
Any other suggestions?
Thanks, and great site!
Old 02-17-2012, 06:44 PM
SD HPOP and a set of stage 2's should get you to 400hp on a stock turbo, but it won't be to happy.
FWIW overall i have roughly $2000 in my injectors, chip, and HPOP(bought another motor), and another $3300ish in a trans. Haven't dynoed or re-burnt the chip yet but i should be at the 400hp mark.
Old 02-17-2012, 06:47 PM
That's what I wanted to hear!
So what's the preferable turbo to have for this application?
Old 02-17-2012, 06:48 PM
dt66, or h2e
Old 02-17-2012, 06:49 PM
The stocker with an intercooler will get the job done, but a D66 or 38r would do better. But the 38r would require swapping over the entire turbo set-up to the SD style to make it work. Otherwise a modded H2E or t4 mount turbo would run great.
Actually with a good set of 2's or hybrids and a turbo you could hit 450hp pretty easy, but at that point you really need valve springs and head studs. And most likely you would need E-fuel.
Old 02-17-2012, 06:51 PM
Jd,
Your 2's run fine on stock fuel, or do you have them turned down with your chip?
Old 02-17-2012, 06:56 PM
Originally Posted by glovemeister View Post
Jd,
So far they seem to be doing good, but the tunes are for split shots so they aren't tuned correctly. I would say its safe to assume that my fuel pressure drops when i really get into it, and it would be happier with e-fuel. But for now its what i'm running and it works.
Old 02-17-2012, 07:13 PM
Who do you recommend for a tranny and t/c that'll handle this kind of power?
Old 02-17-2012, 07:40 PM
BTS is one of the most common mods for auto trans. Spendy but worth it.
Old 02-18-2012, 03:53 PM
Do you HAVE to have an intercooler to run a DT66 turbo? And would the stock auto tranny handle it??
