37" Tires with 4.10 Gears - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-17-2012, 02:00 PM Thread Starter
Thinking about running 37s on my truck. It already has 4.10 gears and have 35s on it now. Runs extremely well the way it is, no power loss or anything. How do you guys think it would tow? Not going to be towing anything extremely heavy, just my wrangler rock crawler every once in awhile to Uwharrie.
1997 F350 SRW RCLB, 4.10s, RSK 4" on 37" Toyo M/T's, Tony Wildman 6 Pos., 3 Pillar Gauge Pod with Trans Temp, Boost and EGT's, BTS Valve Body, AFE Intake, 3" DP to 4" to Dual 6" Stacks, Custom Front Bumper, 12k Winch
Project 5 Speed soon to Come
s.hiles is offline
post #2 of 3 Old 02-17-2012, 03:21 PM
Quoted: 82 Post(s)
Feedback Score: 4 reviews
Probably be fine unless you are towing in the mountains, then you might be looking for more power.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, 38 Gal rear tank, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is online now
post #3 of 3 Old 02-18-2012, 04:55 AM
baderic03's Avatar
Send a message via AIM to baderic03
You'll be fine just watch Trans temp and egts and you will be all set
97 f350single cab auto
4:10 axles spooled front axle
3in down pipe to stack
Intake 6637
140v idm mod
Efuel all built In house
II s475 .90 turbine spool....
Irate T4 304ss up pipes
T500 with gen3 pump
450/400s hush power
Comp built Trans 2100 stall converter
Gearhead tunes
531/1080 on 250/200s
baderic03 is offline
