Possibly buying powerstroke, advice/help needed
Hey everyone, I'm looking at a 97 powerstroke with 107k miles on it. The truck seems to be overall in nice shape. However, there seems to be more blowby than usual, judging by videos I've seen on youtube. I did put the oil cap on top to see if it was blowing off, but it didn't seem to. I'd like to bring a ping pong ball when I go to look at it again to see what happens with that. Is the pressure coming out the real issue, rather than how much smoke? Also, there was some oil on the oil pan. I took a picture, but it's not too great. I was wondering if it's also something to be worried about.
http://img205.imageshack.us/img205/2...0213121343.jpg Thanks in advance! |
It doesn't seem like a crazy amount of oil. Did you pull off the turbo boot and look in there for dusting of your turbo fins? Is it manual, or auto?
if the oil cap stays on there it should be fine.
see if you can figure out where the oil is coming from, doesn't look like a very big leak |
Nope, I didn't do that, but I will look into that. I don't know too much... especially about diesels. Auto... the tranny was rebuilt in October. The transmission pan was wet too... not dripping, but it was wet. The truck seem to run and drive nice... I made sure the truck was cold when I got there, it started up nice, didn't seem to have any smoking issues besides a quick puff of smoke upon starting. After I took it for a drive and pulled the oil cap off, the amount of blowby is what concerned me. It wasn't puffing out, just a steady stream.
Here is my opinion on these trucks. Blue book is just a suggestion. These trucks will only remain about the same or go up in value. A rebuilt motor is esssentially a brand new $30k diesel truck (especially with the mods you mentioned).
My opinion, it is hard to go wrong buying one of these, outside of it having several major issues. That is if you have a good mech or can do it yourself. My mech has been doing work for my family and I for about 4 years now. I do most of my own maintenance outside of something like a motor rebuild, that is outside of my abilities and tools. I asked him about it and he said that he could do it for $1,500 "depending if I wanted a new cam, crank etc.) Now if you look for a FOMOCO engine master overhaul kit it is right at about $1k, so $500 for labor is not all that bad. Now that includes me helping in any way I can as I want to learn not just pay to have it done. Hell I saw a motor the other day with 41k miles that a dude picked up back in 00 or so, and was gonna keep the low mileager around for his tow truck. Never needed it and upgraded tow truck so he was selling the motor for 1k, injectors, turbo, hpop etc. |
The asking price is actually well below book value, and it comes with a plow. I do have a mechanic that is reasonable. I'm gonna go take another look at the truck tomorrow if possible.
As said, it depends on where the oil leak is coming from. See that flywheel inspection plate just aft of the oil pan? Remove it, and look at the back surface of the pan. And look at the cover. The front of the cover has a "flange" that juts forward, and the edge comes right up to the oil pan, and over time, it can "saw" through the pan. You can buy an expensive replacement cover that doesn't have that flange, or you can grind/snip it off. The oil might also be coming from above, from the topside of the engine. How does it look around the base of the dipstick tube, and around the oil filter?
Actually, that plate looks new; the one visible bolt certainly looks new. Hmmm..... |
Damn MP you know your stuff. I was noticing some shine under there too, which is not common unless there has been something replaced. Good eye bud!
Don't let white smoke coming from the oil fill tube scare you off. This will happen with any vehicle and is the reason we need a CCV (crank case vent). Heat of combustion causes oil to vaporize and expand. If the oil fill cap stays overtop the hole, and doesn't float like an air hockey puck you're golden. Really what you're looking for is combustion gasses 'blowing-by' the pistons rings and pressurized the crank case beyond acceptable levels.
