chirping sound - Ford Powerstroke Diesel Forum
Old 02-09-2012, 02:46 PM
chirping sound
Changed the breaks about 3 weeks ago, I had both calipers up front sticking and the breaks were uneven so i just replaced them and the calipers. Then on monday i started to notice whenever I make a left turn I am now getting a chirping sound from what sounds like the front left tire, but it dont happen it all the time. its just puzzling.
Old 03-13-2012, 07:59 PM
this squeak is pretty steady now and also occurs when going down a bumpy road. any one have this problem? I had the brakes checked out and they said everything was fine.
Old 03-13-2012, 10:43 PM
lift every corner and spin the tire see what happens, if LS lift whole rear. may be a bad bearing or hub
Old 03-14-2012, 10:18 AM
Dang, mine is doing this too. Do these have unit bearings or no?
Old 03-21-2012, 11:40 AM
no i dont have unit bearings. I had a u-joint on the drivers side go bad. then it came back, me and the neighbor was checking it out today and the other side is doing the same thing. hope it helps. but i havent got to tear the passanger side wheel out yet.
Old 03-21-2012, 02:10 PM
then i locked it in 4wd and it made a loud bang when turning to the right. so I guess ill have to look into it.
Old 03-21-2012, 04:43 PM
sounds like the axle u joints to me
Old 03-21-2012, 04:59 PM
well is the passenger side hard to change than the drivers side? cuz the passenger was pretty simple.
Old 03-21-2012, 05:10 PM
that one i cant answer yet i havent done mine but im sure they need it
