Rig Advice
Hello All,
I recently joined the forum and I think I've found a good rig in Oklahoma. This will be my first Ford and I would really appreciate any advice that you folks could dish out. Rig: 1997 F250 Automatic 7.3 4x4 with 281,109 miles on it. They have it priced at $5,995. It's a 1 owner truck and the dealer does not have any maintenance records that they can provide. I've asked if they can get me in touch with the PO but they didn't seem like they wanted to do that. Based on price alone, is this something that any of you would drive 3 hours to look at? Thanks!! |
Things to think about, If the transmission goes out it's $4000+ to have it rebuilt.
Did the PO keep the Radiator flushed and good Anti- Freeze in it all the time for the past 15 years and 281000 miles. Doug |
James |
sure go take a look. if they are asking x they will probably take less
when you look at it does it look like it has been taken care of? if it does than it probably has, if it looks like someone spray painted the chassis black they could be hiding some issues and the truck might have more problems. a transmission rebuild is not that expensive. and unlike the 6.0 coolant is not as important. do the the normal things. check the fluids, smell the tranny fluid does it smell burnt. check for leak, the ball joints, the u joints, etc. start it cold does it smoke alot, make any strange noise. take it for a test drive, does it shift through the gears, does it run well, do all the electrics work. locks work? windows work? cruise? ac? shift into 4x4 does it go easily? |
Great advice. I have turned a few wrenches on my gasoline engines over the years but this will be my first diesel so I feel less confident about things to look for. I will definitely check the items that you mentioned. Thank you! |
flip the oil fill cap see if it blows off or vibrates off, check just about anything else you would like a gas, inspect the turbo see if it has an bent blades or any play at all, test drive it see if it goes well, price is pretty nice for the miles, mine has 290k and blue books at 10k
First thing first, have them send you a copy of the carfax (any reputable dealer will have it for free). This will tell you if it really has been a single owner rig.
I always get nervous when I see an OBS at the dealer, or any vehicle for that matter. These guys will do anything to get you down to the lot. Prior to buying my current truck, I found a '97 with 220xxx, less than 5k on a built BTS transmission and 20k on a reman engine. I asked them for the paperwork, and they faxed me some reciepts. Drove 4 hours to take a look. Long and the short of it is that the Vin of the truck didn't match up with the Vin on the reciepts they sent me. They tried feeding me some BS about how the cab of the truck had been swapped due to hail damage. Crawling under the truck, I could tell neither the engine or trans were near new. Needless to say I drove home empty handed, and my complaint with the BBB is still trickling down the pipe. |
x2 on the carfax, that is best bet as well, and sorry bout your luck backwoods boy
to the op
carfax will only tell you how many registered owners a vehicle has had.
it can report the history if it was taken to shops that report that kind of stuff tho
