EBPV question - Ford Powerstroke Diesel Forum
Old 02-04-2012, 10:48 AM
Question EBPV question
Can I just unplug the ebpv?? or do I have to gut it?? Where is the plug??
It seems to stick until the truck is good and hot and if I have to let it idle a little longer without it plugged in then so be it!!! It sounds like Sh*^t!!!!
Thanks in advance!!
Old 02-04-2012, 01:05 PM
It is possible to unplug it. The plug is right under the intake on the comressor housing of the turbo.
Old 02-04-2012, 01:44 PM
Sometimes just unplugging it doesn't always fix the problem. May need to disconnect the control rod and wire the valve open.
Old 02-04-2012, 02:10 PM
unplugging it is easiest, but you can lose a bit of backpressure by gutting it, which is a good thing. or you can turn it into an exhaust brake
Old 02-04-2012, 04:11 PM
Ok thanks!! Exhaust brake wont work with the auto will it?? Or how would I get the torque converter to lock up??
Old 02-04-2012, 04:16 PM
You can make the exhaust brake work, but it can be a bad idea (It does work for quite a few people though). If you want to do that do a little research so you can make an informed decision.
As for the original question. You can just unplug it if you just want to make it stop working, but you do lose some backpressure (which means slightly cooler EGTs) if you gut it.
-Aaron
Old 02-04-2012, 04:24 PM
Ok thanks. I think I will just unplug it for now and maybe gut it when I get a dp and put it in in nicer weather. Too cold to start that!!! and I have to go to work way to early tommorow!!! LOL
Thanks for all the help guys!!
Old 02-04-2012, 05:33 PM
You can use it with the auto but you need a tc lockup switzh
Old 02-07-2012, 04:49 PM
OK thanks for the help. Haven't had time to look at it!!! My wife couldn't get the old girl to start this am... Asked her if she plugged it in and this is the answer I get "Why do I have to plug it in? I don't have to plug my car in so why does it need to be plugged in??" I asked if she used the glow plugs at least.. "what are glow plugs??"
Needless to say she doesn't have a key any more!!!!!
Old 02-07-2012, 05:00 PM
Winning DUHHH
Ive never plugged mine in Then again, your in Ontario! But heck mine started up...kinda pissy in -15°f
