1997 Injectors Fit a 1996 - Ford Powerstroke Diesel Forum
Old 02-04-2012, 10:19 AM
Will they fit i found a set for 100 at a junk yard gonna get them rebuilt. But are the swappable?
Old 02-04-2012, 01:17 PM
Yes, they are the same and will fit. The only issue you may run into is if the injectors aren't stock or are from a CA truck, then you will need tunes to run them.
Old 02-05-2012, 04:45 AM
i bleve its federal emmisions. and are out of a work truck wich is standerd shift. so they will fit? im gonna get them rebuilt
Old 02-05-2012, 07:36 AM
as long as it's not a cali truck the injectors will fit. Probably not many cali trucks in Connecticut.
Old 02-07-2012, 01:41 AM
Is there a tag that says its a califonia truck? Should i grab the hpop also? I want the whole motor but they said no! Reason why i want the hpop is i cant have my truck down when i have them rebuilt daily driver.
Old 02-07-2012, 02:25 AM
Right side(aka pass) valve cover should have a tag with blue writing that talks about cali emissions. I was certain my truck was only 49 state but just yesterday I read my tag and realized I was wrong despite reading said tag.
Old 02-07-2012, 06:26 AM
If the GP relay is still there, look for a metal shunt on it. If it's there, its a Cal truck.
Old 02-07-2012, 12:07 PM
that pass side valve cover will have light blue writing btw, big square sticker towards front of engine
Old 02-08-2012, 09:32 PM
Can you buy the whole motor piece by piece? Still might come out ahead
