OBS straight ayle swap
need info on doin this. like what years will work with my 97 F250. a rough idea what it might cost, etc etc
any D60 from 1986-1997 will work the earlier ones had kingpins the later ball joints. you will need the axle, the proper brakes (they changed somewhere in 95 from slide pins to bolt on calipers) the track bar AND bracket, and the steering parts draglink and tie rod. While these parts are nice to have they are not required the 350 springs and drive shaft. Cost all depends on what you can find an axle for and what you spend on parts getting it in your truck. I did a ball joint one in my 94 and added a locker, hawk brake pads, power slot rotors new bearing etc and have over two grand in it. I am doing one right now on my 97 with a KP axle and will have less than 1000 in it and that includes a locker. If I can sell the rear I bought with the D60 it will be even less.
i would look for a 96-97 ball joint axle and that way you can keep your brakes. here is a link How-To: Dana 60 Swap i will find the other one i like alot tomorrow |
I used a 94 front axle. You gotta change the yoke but the driveshaft is the right length. 95 is the crossover year from the slide caliperz to the bolt on ones. I had to convert back to slide mount calipers but reused thestock linez.
Or swap to sd axles and get 4wheel disc brakes but diff wheels are needed
this is the other link I like
Dana 60 Conversion for F250 years 1986-1996 .: Articles and i lied now with all new steering components i am at 1100 in my current swap. but i hope to sell some of the rear axle parts (got a matched pair and don't need the rear) and the ttb parts to recoup some money |
got a locker for the rear mine is open diff and sucks wen i get in wet grass and do u have gears i would like to put 410 in cause mine is kp axle swaped and i want the rear to match the front
My swap ran me 1100 complete with axle new brakes and lines, new shocks and super duty springs.
I used a dually axle and converted it to fleetsid. Saved money that way. |
I was lucky and found a 89' complete truck with (90,000) in a near by bone yard. they tourched the front whole frame, i got everything for 600. But forgot to put in all new bushings, so after a few good death wobble scares i had polyurithane bushings put it witch brought the whole project cost to about 1000. but it was all worth it in the long run bc it would have run me over 2000. to rebuild my worn ttb.
Terry pretty much covered this all for you.
It all depends on what you find, where you find it, and its condition. Many men have searched years and not found an axle, and some people find them daily for dirt cheap. I had an axle, picked it up for 500 bucks, and then I had about 500-600 in rebuilding it. Either way, the magic number seems to be right around 1100 dollars for a Dana 60 front axle. Id NEVER pay 1000 bucks for one that was just pulled from a truck, and not gone through. At one time, I did find a Dana 60 in a junkyard for 200 bucks. I picked it up, we put a new drag link on it, and swapped it into my buddies F250. He had to re-gear it, but othe than that, I think the total for that thing was under 500 bucks in parts, including the axle. Any axle from 86-97 will work, but the 95-97 brakes are different from the 94 and older brakes. So youll have to do some brake line modifications to use the older calipers. The 91 and older axles are also King Pin, instead of Ball Joint. Kingpins are generally stronger, and will last longer, but are also considered "old" technology, and are harder to align than a balljoint axle. But once done, it will never "fall" from alignment until the king pins start wearing. If you want to go a little more indepth, you can swap to the 99-04 axles, and youll have to do a little more modifications, IE: Brake lines, track bar, get the rear axle, and buy new wheels OR you can go REALLY indepth, and do the 05+ axle swap, and youll have to get a lot more parts, remove a lot more parts, do some welding, a ton of drilling, including what youd need to do for the 99-04 axles. but is completely worth it. Its all a matter of budget, and what you really are capable of/what you want. Last edited by weareweird69; 02-04-2012 at 09:23 AM. |
garrett did a good job of explaining the newer swaps.
these are my experiences: I bought my KP for 500 and it came with a matching rear and everything i needed, but needed to be rebuilt. I had to drive 4 hours to get it round trip. my bj i paid 1200 for it came with the rear suspension and everything i needed, but it had been totally gone through before i bought it. It needed nothing, I torn it down anyway and added a locker, but that was it. I had to drive 12 round trip for it. |
