96 ford 7.3 bogging down at full throttle - Ford Powerstroke Diesel Forum
post #1 of 2 Old 01-31-2012, 04:57 PM Thread Starter
my 96 7.3 has 320000 miles on it and i am having a problem with it when i put the throttle to the floor it bogges down and grey black smoke comes out the exhaust. i just changed the fuel filter and put injector cleaner in the fuel but diddnt solve the problem.
r041594 is offline
post #2 of 2 Old 02-03-2012, 04:38 PM
this might be the prob
check for injector low voltage codes or non responsive injector codes, and low boost pressure signal on responsive. check fuel psi. the injector harness under the valve cover are prob bad i would replace the side that has the faults and the vavle cover gasket it plugs in to.
justinwdiesel is offline
