What would you do?
I just bought a 97 OBS F250 4wd ext cab and have not driven yet because the passenger front spring is broken. Here are my choices as I see them.
Buy a new spring $179. Buy a used spring and replace the one side.(unsure of price) Buy 2 used springs and replace both. Look for a Dana 60 and do the swap.($600-$1000) Buy a 4" lift kit from skyjacker.($1100) I guess the easiest would be to buy one spring and replace it and then in the spring start thinking about the Dana 60 swap? I just hate to spend Nearly $200 for a band-aid type job. I am in upstate NY and it is the dead of winter so I really don't want to be doing to much suspension work outside if I don't have too. Sorry if this is a newbie question..... just thought I'd throw it out there to get some opinions. Thanks for any advice you may offer |
Your truck wont sit straight if you only do one side, probably wont drive very good either
i have 4 spare ttb springs. but i would suggest a d60. i have done one and i'm in the process of a second hence why i have 4 ttb springs
if you want to drive to pa ill give you 2 good used springs
IMO get a D60 and use our RS kit and SD springs if you want ride quality..
if you have the money, just do the d60 swap, otherwise band aid it till you do
