7.3 Engine Rebuild Need Input
Has anyone on this sight rebuilt a 7.3 and what is the average cost? Where is the best place to buy a KIT from? I love my
and it only has 234,000 on the clock now, but I always hope for the best, but look for the worst. I figure I got at least another 100,000 to go but want options in case anything does happen.
I believe you can buy a rebuild kit from Ford for about $2k.
I've got 260K on mine. Pulled the engine to repair oil leaks. Thought I'd look at the main and rod bearings, they were toast. Cyl walls looked good though.
Price breakdown is generally.
~ $1500 for rebuild kit. ~ $700-$2000 in machine work (bore job vs deck resurfaced etc) ~ $600-$1200 for a new turbo (no point putting a tired turbo on a new engine) ~ $300 in fluids ~ $150 for a new water pump This is assuming you're doing all of the assembly work yourself. If you take it to someone they'll probably charge in the ballpark of $5k, and re-use the old accesories. Really boils down to how the engine has been maintained, and how worn out she is. Last edited by backwoodsboy; 01-30-2012 at 04:42 PM. |
You could make the rebuild even more worth it and do a bunch of performance mods while you've got everything apart and come out with a basically new beastly motor
if you don't want to or can't do it yourself you can buy a long block crate engine, just do a bit of research as the prices and builds vary.
I'm getting ready to do a upgrade rebuild to my spare engine and I'm budgeting about 2k. That's with my replacing all the bearings, seals, head gaskets, getting the heads/deck spec'd out & an ARP stud kit, and I'm debating the water pump.
^^You must be getting a good deal on parts or machine work
1k for the kit, 600 for arp, 150 for water pump. So like $300 for machine work?
I'm doing the honing myself, I just need the specs checked for me
