Need New Injectors - Ford Powerstroke Diesel Forum
Old 01-28-2012, 11:06 AM
Need New Injectors
It's time for me to get new injectors. I would like stage 1 injectors where would be the best and cheapest place online for me to get a new set?
Old 01-28-2012, 11:07 AM
seems like most people on here like rosewoods.
Old 01-28-2012, 02:45 PM
I second the rosewood folks. They'll replace all the wear components and flow test them, essentially giving you a new injector for far less than what a new injector would run. You also have the option, if you want stock performance and can afford to have your truck down for a week or two, to send them your injectors and they will flow test and blueprint your injectors, replacing components as necessary to make your set operate like new, for less money than a full 8-injector rebuild (assuming some of your injectors don't need work).
Me, I'll be sending off my cores to get some stage 1 sticks. I don't feel like doing much more than tunes, 17 deg HPOP, Superduty-style electric fuel pump, and leaving my LuK single-mass flywheel stock-power clutch in place. I hear stage 2's are a bit rough on the ol' stock strength clutches.
Old 01-28-2012, 06:14 PM
Full A-Team Member
Yes 2's would be hard on a stock clutch. 2's are capeable of over 400 hp
Old 01-28-2012, 08:06 PM
Send a message via AIM to baderic03
Mhmmmmm 400+hp I like
Old 01-29-2012, 05:01 AM
Always hear good things about rosewood and beans. 400hp wouldn't last long on stock clutch
Old 01-29-2012, 02:51 PM
the baconator
or a stock turbo.
