Does any one know where I can get replacement plugs for wiring harness on a 97 250 diesel
It seams rodents like my engine compartment when it is raining and chew wires this is the second time now it is chewed right next to the sensor. And I don't know what it is, driver engine valley front, 3 wires don't remember colors I think 1 is black w/ white stripe and 1 is yellow. I get the melo drama from daughter (13) B |
The UVCH is probably what you're looking for. Pics just to be sure?
hpop gauge? piks would help alot better
UVCH is five wires. There is no factory HPOP gauge. The sender for the dash "gauge" is on the HPOP reservoir, but it reads LOW (i.e. lube) pressure, and it's just one wire. Yeah, a pic would be helpful. What does it plug into? The fuel bowl? The left side head?
Don't know about the wire colors, but is the sensor on the front of the driver's side head pointing inward at 45 degrees? If it is, it's the Injection Control Pressure (ICP) sensor. Here's a part number:
ICP Sensor Connector (repair connector with 12” pigtails for ICP, EBP sensors) (Ford) 5C3Z-12224-A (International) 2501105C1 Cheers! |
That's what I needed found one on ebay, didn't want to go back to the same shop that worked on the truck before.
Thanks Brian |
glad you got it figured out, are you gonna do it yourself, or find a new shop?
there is an hpop sensor that the pcm read, and the oil gauage in the cluster only reads wether its wrorking or not, doesnt actually read pressure |
True, but there's no gauge involved.
ahhh, gotcha, i have an hpop gauge on the sensor, thats why i mis lead myself, i meant sensor in my first post
