The "ultimate Gauge"
so i was reading one of my deisel power mags and saw a write up on an Aeroforce Gauge. thought they were pretty cool anybody run one of these gauges in there trucks??
i think frank "ol blue" is trying to install one or finished in the performance section, and garrett "weareweird69" has one iirc
I am running 2 of them with add sensors for fuel PSI, EGT, and bost PSI. These 2 gauges allowed me to go from 4 gauges on my pillar and steering column to just 2 gauges.
I have mine set to scan between boost, fuel PSI, transmission temp, EGT, HPOP PSI, and HPOP Duty Cycle. They can read anything the PCM can read. They also can do a CCT and injector buzz test. I like having 2 of these instead of 4 of the others. |
What do you need to do to get this to read EGT? Does it require an additional sensor?
are these cheaper????
Sensor & Control Box: Aeroforce Technology Inc | Products - Sensors I have a total of $650 in both my ScanGauges and all the extra sensors that I have installed (fuel PSI, boost PSI, and EGT). |
well i ordered 1 last night. 250+10 shipping right at the aeroforce web sight. should be in by friday. ill let u guys know how it gose. Im just happy i dont have to drop big money for a good scan tool with the buzz and cyl cont. tests on them.
these gauges scan the codes right? do they tell u the Code #? and do they clear codes? |
that makes the price difference worth it |
mrjonesjr
Do you think I will need the boost sensor? I am running stock injectors and HPOP. |
