Fill mod
Hey guys,
So as you know I have the flatbed on my truck. I have it up about four inches from the frame (bare min to get any decent amount of flow). It looks good and it fills pretty ok. I have gutted the black hose in my fill neck. On the front tank I have also identified the vents. In terms of the vents can I just do the rollover valve mod and then run it to my frame instead of running it to my filler neck? There is no way to do the deal where I drill into the filler neck. So will my half hearted attempt at it work?
Are the cab and chassis rollover valves being made again or will I have to do the plastic barb idea?
