Truck keeps stalling/missing - Ford Powerstroke Diesel Forum
Old 01-15-2012, 02:17 PM
Send a message via MSN to 95_Powerstroke
For the past couple of days when I drive my truck when its cold it sounds like it has a miss and bogs down and then eventually stalls and then the truck dies when you try to accelerate afterwards. One thing I have noticed is that the fuel bowl is ice cold when it misses like this and then when I pull over and keep it revved to about 1800-2000 for a few minutes it clears up and runs just fine when the fuel bowl is warm to the touch. Any ideas on what this might be?
Old 01-15-2012, 02:46 PM
fuel bowl heater maybe?
Old 01-15-2012, 03:01 PM
That's what I was thinking but I am not sure if cold fuel would cause it to do what it does?
Old 01-15-2012, 03:24 PM
is it throwing any codes? and you said it runs good when warmed up on the bowl situation
Old 01-15-2012, 03:25 PM
What is the temp outside when it does this
Old 01-15-2012, 05:17 PM
I have no way of testing the codes unfortunately.
Anywhere from low 30's to low 40's.
Old 01-15-2012, 06:48 PM
So fuel isn't gelling up so bowl heater isn't an issue.
Probably need to watch your fuel pressures.
Old 01-16-2012, 07:07 AM
definitely not gelling then. Have you changed your fuel filter and checked your pressure?
Old 01-17-2012, 09:39 PM
Brand new fuel filter, have not been able to check fuel pressure. Talked to a diesel shop today and the guy said it might be injector seals. I'm going to take it in there soon and have them run a diagnostic on it and find out what's up.
