What is this part called? - Ford Powerstroke Diesel Forum
Old 01-15-2012, 08:58 AM
Can anyone tell me exactly what the pressure switch or sensor with the single red wire going to it is called? I went to Autozone and they couldn't locate it in their computer. He pulled up a fuel and oil pressure sensor but it had 3 prongs on it while this one has only one connector on it. Any replies will be greatly appreciated.
Thanks
Old 01-15-2012, 09:13 AM
That's the water in fuel sensor. It's not really needed. Sometimes when they get old they start to leak fuel. You can take it off and plug the hole with an 1/8 npt plug.
Old 01-15-2012, 09:16 AM
Thanks Sgt Dave! That's exactly why I'm asking. This thing is leaking like crazy. I'm off to Autozone again!
Thanks a bunch!
Old 01-15-2012, 09:23 AM
Your welcome. Id be surprised if autozone carries that sensor. You'd be better off going to the hardware store and buying the plug.
Old 01-15-2012, 10:28 AM
I thought that is the fuel bowl restriction sensor? p/n E8TZ-9S283-A
Old 01-15-2012, 10:44 AM
Thats what it is, couldn't remember what exactly it was called. I replaced one on my dad's truck.
Old 01-15-2012, 12:16 PM
The only reason I knew was I just replaced the damned thing on my truck. It actually was leaking through the electrical wire.
Old 01-15-2012, 12:22 PM
A brass plug is cheaper than a sensor you can do without.
Old 01-15-2012, 03:51 PM
Whatever it was, there's a brass plug in it's place now and the truck runs fine without it. LOL!
Old 01-15-2012, 06:00 PM
A little FYI on the subject. Since there seems to be a conflict between it being called a water in fuel sensor or a fuel filter restriction sensor, I may be able to shed some light on it in case anyone is not aware of the following. Most diesel fuel filters are designed to swell up if they get wet with water so they do no allow fuel to pass through them. With that said, I can see where it is called both. If I had to guess, I would be willing to bet, it senses the pressure on the output side of the filter and only knows if there is not enough fuel being allowed to come through the filter. In other words, it works in either case; If water has it swelled up enough not allowing fuel to pass through it or trash has restricted fuel from passing through it.
Any way, thanks for everyones replies! I have it plugged off for the time being, but will order one from NAPA this week.
Thanks!
