NEWBIE... Air Filter Question - Ford Powerstroke Diesel Forum
Old 01-13-2012, 11:39 AM
ok so like the title says i need help with an air filter... so i have been poking around on other threads and keep seeing that everybody is pretty much running the NAPA 6637. and i havent yet really got a straight answer on why everybody chooses it over something like a K&N! or something to that nature! it seems like the K&N would flow more air which would give my truck more power. but can somebody tell me in detail why the 6637 and WHY NOT the K&N?
opinions are always welcome!!!
Old 01-13-2012, 11:53 AM
Keep reading. The problem is that the K&N filter and others like it have a tendency to let a lot of dust through them even when properly maintained. If you look through a K&N even brand new and freshly oiled you can see a lot of pinholes in the gauze. These pinholes let a lot of dirt through on these engines because they flow so much air all the time (no throttle plate to stop air flow like a gas engine). A 6637 air filter IIRC has three times the amount of pleats than the K&N so there is a lot more filtering surface.
Old 01-13-2012, 11:55 AM
Many say the 6637 filters better and some argue flows well because of its many pleated surfaces. Many say that while the K&N (or other oiled-cotton types) does flow lots of air the filtering isn't as good because of the turbo sucking air through it faster than a non-turbo engine would so it doesn't hold onto as much of the dirt.
Be prepared - You WILL get opinions on this topic.
So, while I'm here let me issue a WARNING. Address the question put before the membership, but don't go after another member who may not share your opinion. Sometimes these threads go south. The mods only let them go so far before they go away.
Thanks!
Old 01-13-2012, 12:06 PM
the 6637/donaldson/fram ca 8037 are thicker, and while they do not allow as much air as fast as a k&n, they allow a hell of alot more than stock, but filter the air coming through much better than stock, and oiled filters like the k&n, because of the very high flow rate of the k&n and the less filtering will dust the turbo, and pit it, this is no good for a turbo because it just causes them to fail that much faster.
Old 01-13-2012, 12:11 PM
Thanks!
so in turn even if the 6637 does not flow as much air as the K&N the 6637 is protecting your turbo which therfore gives you the same amount of power as a K&N? correct me if im wrong please.
sorry for the stupid question but im new to the diesel world and want to protect my investment just as much as anybody else..
Old 01-13-2012, 12:12 PM
the 6637 protects and is comparable to the k&n, but the k&n will out flow
Old 01-13-2012, 12:15 PM
Gotcha! that answers alot! im glad to know that the K&N's dont protect as well now! off the top of ur head how much does a 6637 cost?
Old 01-13-2012, 12:17 PM
I'm pretty sure that it has been proven that the 6637 will flow just as much as the K&N and even if it flowed slightly less the knowledge of the turbo lasting is well worth it IMO. I have pulled an repaired several turbo's for people that where running the K&N filters and it's a real PITA.
Old 01-13-2012, 12:19 PM
anywhere from 35-67 is what people keep saying, i used the fram ca 8037, cost $20 so just shows im cheap, but the filter is almost exact same, its orange tho, and from what i have read, none of these are hydrophobic, thse tend to cost a bit more
Old 01-13-2012, 12:20 PM
I'm pretty sure that it has been proven that the 6637 will flow just as much as the K&N and even if it flowed slightly less the knowledge of the turbo lasting is will worth it IMO. I have pulled an repaired several turbo's for people that where running the K&N filters and it's a real PITA.
yea i will definatly take the safety of my PSD now that i know the 6637. i would much rather be safe then run a K&N for more flow and be sry! only seems smart!
