97 powerstroke - Ford Powerstroke Diesel Forum
Old 01-11-2012, 03:29 PM
97 powerstroke
would not start took battery cable off to clean and it started the next day would not start tried taking battery cable off still will not start
Old 01-11-2012, 04:48 PM
Wts coming on? Tach reading anything while cranking? White smoke? Cranking fast enough?
Old 01-11-2012, 05:12 PM
cranks normal tach about 1 or 200 no smoke
Old 01-11-2012, 05:16 PM
short buzz after wait to start light goes out
Old 01-11-2012, 05:28 PM
So you took the battery off for what reason?
Lastly, you are cranking really good but simply not firing is that correct?
Old 01-11-2012, 05:35 PM
took battery terminals off to clean them and turning over good and a short buzz after wait to start light goes out
Old 01-11-2012, 06:00 PM
This isn't chat. It's extremely hard to understand what you're saying/asking without complete sentences and punctuation.
Have you tested each battery? You have to test them with them isolated from one another. Load test each one.
Have you uncapped the fuel bowl to see if it's full? Also pull the top plug off the HPO reservoir and peer in to check the level.
Old 01-11-2012, 06:18 PM
sorry about lack etiquete today is my first time here but i will try harder to be more informative and descriptive i have not load tested batteries i just volt tested 12.75 both have not checked fuel bowl yet or hpo resovoir and should resovoir be full
Old 01-11-2012, 06:21 PM
it also makes a short buzz after wait to start light goes out
